1999 Honda Accord V6...Evap question...Switch Question
Old Aug 14, 2009 | 11:24 AM
greg05
Default 1999 Honda Accord V6...Evap question...Switch Question
I have a 1999 Honda Accord and when I am driving it; it shuts off. Then I have to wait awhile before it starts back up.
I have the error code for the EVAP Canister and the EGR valve. Could that be the problem or could it be the switch?
Thanks for any help.
This is what read out at Autozone.
Mission contol system leak detected ( Control Canister System)
Probable cause:
001 Loose fuel cap
002 Vapor canister saturated
003 Failed vent solenoid
004 Fail purge solenoid
Old Aug 14, 2009 | 12:07 PM
EGR might cause a stall, or at least stumbling & sputtering.
EVAP leak will not cause any difficulty in running at all.
Check out P1457 in the "DIY Answers" section. On an Accord, there's more possibilities than you listed. But a loose gas cap would cause P1456 instead.
In the future, it's more helpful if you get the actual error code numbers P1457 or P????.
Old Aug 14, 2009 | 01:27 PM
greg05
OK..... Thanks.
Now my car won't start and when it does it dies out.
When I turn the key on and the Engine light is "ON" then it will start.
When I turn the key on and the Engine light is "OFF" then it won't start.
Old Aug 14, 2009 | 02:46 PM
Check to see if it makes any difference to hold the key a bit into the starting position. Don't quite let it go, but just enough so the starter motor quits.
If that helps, then it sounds like a flaky ignition switch.
Old Aug 14, 2009 | 02:52 PM
deserthonda's Avatar
i agree with Jim,,,,,,,,,,, there was a recall of the ignition switch did you have it done ??
call the dealer give them the VIN # and they will let you know if it has been done ..
Old Aug 16, 2009 | 06:50 PM
greg05
I have found out that when I turn the key on....I do not hear the fuel pump humming....Would that be the Solenoid?
Old Aug 16, 2009 | 07:18 PM
It could be the main fuel relay that supplies power to the fuel pump, the pump itself, or possibly the ignition switch.
Check for power and ground at the fuel pump electrical connector. The main fuel relay supplies power for about ~2 seconds while the MFR when you initially turn the key to the II position, so you may need an assistant.
As for wire colors, electrical connection, get a 98-02 shop manual from the online manuals link in the DIY section. Its an iso file, so you will have to burn it to a CD for it to work.
Old Aug 17, 2009 | 08:22 AM
If you hear the main relay click, but the pump doesn't run, then I'd suspect a bad relay or wiring back to the pump.
If the main relay doesn't click, then I'd suspect the ignition switch. Or the wiring from the switch to the main relay.
Nov 9, 2011 02:52 PM
muffinman617
Jul 13, 2011 10:10 PM
hondadude
DIY Answers.
Mar 2, 2010 09:21 AM
JimBlake
DIY Answers.
Aug 6, 2009 01:36 PM
jdelgado
Oct 29, 2007 09:49 PM
