2000 accord rear drum problems. NEED HELP ASAP!!
Old Aug 15, 2009 | 05:31 PM
petef23a's Avatar
Default 2000 accord rear drum problems. NEED HELP ASAP!!
hey guys i was working on my car today trying to get my back brake shoes up for better braking power. anyway i was trying to take off the drum by using bolts on thoes thread holes. we'll one bolt broke and the other one striped the threads right off!
now i have a back drum with no way of taking it off. any suggestings on how to get the damn thing off. because once i get it off i think im ganna get a new one. it sucks tho because they are fairly new. like 2 months old. please help me out.
Old Aug 15, 2009 | 06:33 PM
If you can get the broken bolt out with vice grips, you may be able to re-thread both holes for a bigger bolt.
You will likely have to drill out the original hole in the drum with bit about the size of the tap. I think that I bought a set of titanium drill bits and they went through a rotor bolt with no problems compared to the steel bits.
Use two high grade bolts (like 8.8) that will not snap off.
Turn each bolt 1/4 turn and keep working back and forth.
Maybe apply PB blaster in appropriate spots to eliminate some friction. Use anti-seize on metal to metal contacts when reassembling to prevent this from happening to you again.
Old Aug 16, 2009 | 02:18 AM
finch13's Avatar
I usually use a large mallet or 3lb. hammer to break the drum from the hub. Make sure you're emergency brake is down all the way, if it's engaged a little it can stop you from taking the drum off. I've never used those holes successfully before
Old Aug 16, 2009 | 08:47 AM
deserthonda's Avatar
if someone replaced drums 2 months ago and they are this hard to come off,, i would have to assume that they adjusted the rear shoes way too tight ,,or like it was suggested make sure that the e-brake is all the way down ,,,
if drums are this new , they should come off real easy ,,,,it is when they are really rusty that you would need to use those bolts to remove the drums ,,,,,
Old Aug 16, 2009 | 12:30 PM
petef23a's Avatar
they are not that rusty. because i used that same bolts to take the other side off to adjust the brakes. and its not tight because i would be taking it off if they were tight.
the bolts i used were stainless steel so that could have be it. its a soft steel. ill try to wack them really hard to break it free. wish me luck. damn drums
Old Aug 16, 2009 | 07:24 PM
petef23a's Avatar
got er boys. hit it with a hammer and she broke free. thanks for the help.
Old Aug 17, 2009 | 08:23 AM
Anti-seize for next time...
dioalp
Aug 6, 2011 09:48 AM
sean
Jul 19, 2011 12:31 PM
jerrym
Sep 25, 2010 12:27 PM
62maxx
Dec 12, 2007 03:14 PM
