1999 honda idle issues after timing belt change
Old Jan 3, 2013 | 12:11 AM
mike186abl's Avatar
Default 1999 honda idle issues after timing belt change
hi guys i just did a timing belt water pump seals the whole nine yards on a honda accord and i just finished it off and started the car up after topping off the fluids and when i started it up it had a really high idle like 5000 rpm so i shut the engine off ASAP what went wrong.
Old Jan 3, 2013 | 12:01 PM
High idle usually means massive vacuum leak; PCV disconnected, vacuum brake booster line open, etc. Inspect your engine vacuum lines carefully, esecially large ones.
mike186abl
Mar 22, 2023 09:24 AM
KincaidChance
May 3, 2011 01:13 AM
drummer1279
Jan 16, 2011 09:34 PM
lvs4rock
Oct 28, 2010 01:46 AM
