2000 4cyl coupe oil in the plug boots
Old Jan 2, 2009 | 10:49 AM
secureone
Default 2000 4cyl coupe oil in the plug boots
only in the middle 2
o rings on the piston?
Old Jan 2, 2009 | 02:16 PM
Default RE: 2000 4cyl coupe oil in the plug boots
Nope.
Get a valve cover gasket set that comes with the bottom gasket and 4 seals for the top. The ones on top seal the spark plug tubes and prevent oil from entering from the top. Yours are likely worn out.
I think there is a writeup in the DIY section on this.
Old Jan 3, 2009 | 12:11 AM
secureone
thanks i will check that out
forthewin
Dec 22, 2014 07:51 PM
BlackLX4
Oct 16, 2014 12:28 PM
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
Kyles1999
May 16, 2011 11:38 AM
jon02accord
Mar 26, 2008 10:54 AM
