Oil soaked plug upon reomval of plug wires
Old Mar 12, 2012 | 03:31 PM
wannakeepmy94Accord's Avatar
Default Oil soaked plug upon reomval of plug wires
Greetings. I'm new. I have a 1994 Accord LX with 174,000 miles. I'm no mechanic, but I can handle small, uncomplicated repairs. Upon removing one plug wire yesterday, the plug was drowning in oil up to the tip. The remaining three had the same condition. I realize that the plug port O rings may need replacing, but I'm perplexed why the car runs well if oil may still be on plug.
I will say that each little "boot" from the plug wires came off upon pulling out wire. I had to dig down to retrieve each one.
Does this sound like the four O rings need replaced? This I can do. Gasket replacing I am afraid of.
If what I describe is classic little O ring trouble, I'm game to do the work. If after 174K, this could be bigger than me, it's off to the mechanic.
Thanks
Old Mar 12, 2012 | 04:10 PM
czr's Avatar
czr
Thanks
This to me would be the reason....might as well do the complete valve cover replacement. its not to hard to do either.
Old Mar 14, 2012 | 02:10 PM
Hello New Member..now this is in the correct forum...
Please watch that you post in the correct forums..
Old Mar 14, 2012 | 04:00 PM
brayner's Avatar
welcome wanna!
you have come across one of the most common complaints for this model. Purchase a valve cover gasket kit and replace all the bits. It's a bit tedious, but not too difficult
Old Mar 14, 2012 | 08:06 PM
EXV6NIGHTHAWK's Avatar
The little doughnut gaskets that go under the valve cover are the easy ones. The o-rings, which are under the rockerarm assembly, are a lot more complicated to change. Remember, the valve cover bolts/nuts are only tourqed to around 10 ft-lbs. You can easily snap the little studs if you tighten them too much.
Tony Frattle
Jun 29, 2012 09:38 PM
9foaccord
Jun 13, 2011 07:45 PM
riverman
Jan 13, 2010 09:35 AM
mfre1111
Feb 7, 2008 10:44 AM
Calevra18
Sep 16, 2007 10:45 PM
