2000 Accord A/C not working
Old Jul 15, 2006 | 05:19 AM
pare618
Default 2000 Accord A/C not working
I have 6 yr old Honda accord in mint condition and recently I noticed that A/C was not getting cold enough. Suspecting leak, I put freeon in the morning and by the evening A/C will blow warm air. I did that using a/c recharge kit from wal-mart.
Today, I took my car to a mechanic. He ran his system to evacuate completely and put new freeon. After this was done, now my a/c constantly blows warm air and the hi pressure side is cold while cold pressure hoses are warm. The mechanic tells me that expansion valve is clogged, so i need to replace that and receiver drier too, take compressor out, flush the whole system and add new free on, all for $500 or so.
Is this the correct diagnosis? Should I take second opinion?
TIA,
-Perry
Old Jul 15, 2006 | 11:19 AM
Chiovnidca's Avatar
Default RE: 2000 Accord A/C not working
ORIGINAL: pare618
I've seen alot of bad expansion valves, never seen one cause the high side lines to be cold. I'd be looking for a restriction in the high side between the compressor and the point that it is cold.
Old Jul 15, 2006 | 02:12 PM
deserthonda's Avatar
if the expansion valve wqas bad the tech should have known it right away from the pressure readings ,
post the pressure readings here .. it will tell us a lot more of what is going on,,,,,,,,,,,
LaGirl
Apr 24, 2012 05:29 PM
jayy123
Nov 1, 2011 09:36 PM
MoDawG
Dec 10, 2009 07:00 AM
sthavorn
Apr 7, 2007 10:12 PM
arunsam3000
Mar 6, 2007 01:40 PM
