2000 Accord keeps cutting off
Ok I can't fogure this one out. I've searched the forums but I don't see a similar question.
I have a 2000 Accord with 235k miles as my daily driver. The engine runs smoothly, accelerates like she's supposed to, starts fine and basically no problems except....
The problem:
She will cut off while driving but immediately restart. It happens often but not all the time if that makes sense. I don't know when it will happen or what causes it but once it starts during a trip it's pretty consistent until I turn off the car at which point everything dies. I've also noticed, at least I think, that it doesn't happen as often on colder days. I'm in VA so that's anything under 35 degrees.
The symptoms:
1. In stop/go or slow traffic, pretty much anything under ~50mph when I release the accelerator it cuts off but restarts immediately.
2. If I'm completely stopped it stays on...idle is smooth
3. However once I get to my destination and cut off the car, all power dies. Sometimes the power will come back on within ~20 secs (I know because my alarm goes off). Other times all I have to do is touch the power cable connected to the battery and the power is restored immediately.
Diagnosis:
I was leaning toward a short but I can't explain how the car will stay on at higher speeds or will stay on until I turn the car off.
I can't afford to start randomly replacing parts so I'm looking for some insight from you guys to narrow down the issue. Thanks
The problem:
The symptoms:
Diagnosis:
Can you make it happen by wiggling the key? Flaky ignition switch is not very rare.
If you CAN make it happen, then you have a flaky ignition switch.
If you cannot make it happen that way, it doesn't really prove the switch is OK.
dantheman170
Oct 4, 2009 10:21 AM
