2000 Accord se, 4cyl, vtec radiator fan?
Old Jun 29, 2011 | 10:27 AM
Star68's Avatar
Default 2000 Accord se, 4cyl, vtec radiator fan?
I recently swapped out a busted heater hose in my 2000 accord se, in doing so I replaced the radiator coolant. Everything works fine, but my radiator fan never comes on. The car runs fine, temp gage never moves above half. Is this normal..... especially driving in Florida?
Old Jun 29, 2011 | 10:42 AM
TURBOKRAUT's Avatar
did you use full strength coolant?
turn on your AC and see if your fan comes on. if not check to see if you plugged it in all the way, check your fuses.
Old Jun 29, 2011 | 12:29 PM
Does the condensor (driver's side) fan come on? If yes, you have a bad radiator fan, fan relay, damaged wiring, or unplugged as TK suggests.
If neither fan comes on, but they do come on w/ AC, thermoswitch A may have failed open. It's supposed to close when coolant reaches 194F and allow the radiator and condensor fans to cool (w/o AC).
Old Jun 29, 2011 | 08:02 PM
Check the Common DIY Threads-second from the top-for how to jump thermo/switch a....do the fans come on....double check the connector, busted hose could have gotten coolant in there and cause issues.
hondagal74
Aug 14, 2013 09:05 PM
Novaknowledgenow
May 30, 2013 08:58 PM
jayhawkdad
May 31, 2012 12:09 AM
911michael
May 17, 2012 05:59 AM
daddy
Feb 6, 2006 02:52 AM
