2000 Honda Accord - 3.0 V6-shifter bezel
Old Mar 27, 2011 | 02:59 PM
page's Avatar
Default 2000 Honda Accord - 3.0 V6-shifter bezel
Does anybody know what the little hole(opening) to the left of the "P" - park- in the shifter bezel of a 2000 Honda Accord with automatic transmission is for? I'm not sure if this opening is supposed to have a little plastic plug in this hole or not or if it's used as a port to plug in some kind of tool for diagnostics?
Old Mar 27, 2011 | 08:39 PM
Buckeye Accord's Avatar
It is used by the factory to put the car in neutral. You stick the key in the hole and push down, then you can move the shifter out of park.
Old Mar 27, 2011 | 10:12 PM
And use that in case your brake/shift interlock system fails. If it won't let you shift out of PARK, that's the emergency release.
Old Mar 28, 2011 | 12:38 PM
page's Avatar
Smile
Thanks for the info! I appreciate it!
Old Mar 28, 2011 | 12:42 PM
page's Avatar
Thanks for the information on the small opening in the shifter bezel! I appreciate it!
rob.c1989
Apr 8, 2013 08:47 PM
myredhonda
Oct 30, 2007 12:38 PM
WhyNotFab
Oct 17, 2006 03:12 AM
Markus26
Mar 8, 2006 02:16 AM
