2000 honda accord hesitation issue...anyone know whats wrong?
Old Mar 20, 2011 | 08:15 PM
rusty's Avatar
i agree sounds like egr ports to me too
Old Mar 21, 2011 | 06:30 AM
bushcal's Avatar
Default car fixed
IT turned out to be the alternator....now the problem is all fixed up.
Old Mar 24, 2011 | 11:34 AM
dave's Avatar
thanks bushcal. i will tell my mechanic to take a look at that. did you have anything else besides the distrubutor changed before the alternator was changed. my mechanic already changed the distributor and temperature sensor (already paid over $300) and the same problem exists. how did your mechanic reach that conclusion?
Old Mar 24, 2011 | 07:45 PM
Dave- What car do you have. And do you have any codes.
My egr post was for "gator".
The P1381 and alternator are a known issue
honda-tech.com/showthread.php?t=2813513&highlight=alternator
Old Mar 26, 2011 | 12:18 PM
bushcal's Avatar
Have you looked at egr/egr port issues? Only when warm and in that rpm range suggests that could be the issue....
all it was was the alternator
Old Mar 26, 2011 | 12:37 PM
Originally Posted by gatorguy
I have the same problem with a 1996 VTEC. No codes stored. It hesitates only when warm and only between 2000-2500 rpm. Any help is appreciated.
There are multiple people posting for help on this subject. Again, "gatorguy" has a totally different issue than what "bushcal" had. Also a different generation car.
EDIT: Still not sure what "dave" has. Could be the same but without knowing year? Also not sure if he has CEL codes are not.
Last edited by poorman212; Mar 26, 2011 at 02:35 PM. Reason: Added more for the "other" posters-dave, gatorguy
Old Mar 26, 2011 | 05:55 PM
  #17
dave's Avatar
sorry, i should've indicated my car earlier. i have a 2000 accord ex with 203k miles and exactly the same problem that bushcal had, i thought i was the only one with this issue. i'll finally have some time to get to the mechanic. thanks again for your help bushcal, keeping my fingers crossed
Old Mar 27, 2011 | 11:32 PM
  #18
f1swede's Avatar
Default Hesitation
Hello! Im new to the Honda forum but not new to Hondas products. I would go along with Poorman212 with EGR ports. Recently bought 95 Accord ex 4cyl for my daughter it has 187000 miles on it. The first thing i did was clean the Intake manifold and EGR port/channels before the car did not run very good but after cleaning totally different car. Hope i helped somebody. Thanks,F1swede
Old Aug 9, 2011 | 10:54 PM
  #19
HonkinHorns's Avatar
Default 99 dx with exact problem midrange rpm hesitate after
warmed up....
so 1st effort was to disconnect the temp sensor, and problem gone; plug back in, prob back, so i figured that's it, replaced sensor.... NOPE...
then deducing that the temp sensor tells the brain what to do with egr.... so looking into that....
i sure can't see how it would be the alternator, how would it be? puzzling...
Old Aug 10, 2011 | 06:23 AM
  #20
bushcal's Avatar
it was actually the Honda dealer that told me the alternator was bad....I would never take the car to Honda only under circumstances like this. anyways paid the 100 diagnostic fee and bought the alternator from them then I simply changed it. Only way i checked to make sure that was the issue was i ran the car till it started acting up...stopped, disconnected the alternator, ran it again and all was good. highly suggest if the problem is in fact your alternator get the one from the dealer...i have read about compatible issues and such...hope this helps man
