2000 Honda Accord sedan ex front brakes locking up
Old Sep 7, 2020 | 08:49 PM
Casey Lembo's Avatar
Default 2000 Honda Accord sedan ex front brakes locking up
My 2000 Honda Accord from brakes are locking up after awhile driving just replace the front brake pads and rotors put new fluid in and bled the brakes and car drives fine and brakes fine and then after sometime driving the front brakes just locked up had to really push the gas pedal in the car barely moves brakes were smoking by the time i got home. What could it be?
Old Sep 8, 2020 | 12:17 AM
Not much if this is the front brakes. Either the caliper is stuck for some reason or the brake pads are wedged into the caliper bracket.
Pull the wheel, unbolt the caliper on the bottom bolt. Does the caliper swing up or is it stuck on the brake pads? Can you slide the brake pads in the caliper bracket with a slight drag?
Old Sep 8, 2020 | 01:35 AM
I will check that. it's weird it seems to me that both front brakes fully lock up once the brakes get hot or just from driving 10 minutes or more and after that I let it sit when they where locked and smoking then Tried to Drive again and they weren't stuck locked up anymore.
Old Sep 9, 2020 | 03:28 AM
The Toecutter's Avatar
I've run into this on other models of cars and trucks, and what I've found is it's time to replace the brake hoses, as they've collapsed internally.
Old Sep 9, 2020 | 07:20 AM
Seanjordan20's Avatar
It sounds like the hoses to me also. I had a friend that had a 99 accord and paid shops to fix the issue. After replacing almost the whole system she gave up. I asked her to let me try replacing the hoses and it fixed the issue.
Old Sep 9, 2020 | 02:24 PM
Another vote for replacing the hoses. They trap fluid in the calipers; when that fluid heats up & expands that "applies" the brakes.
Old Sep 9, 2020 | 04:31 PM
nomad2020's Avatar
If all was fine before you replaced pads and rotors i would first double chk your work make sure you installed everything properly
also chk the adjustment on the brake booster rod i have seen that more than once but usually after replacing brake master with a cheap non honda one ,,, ,but i am leaning toward bad hose(s) as well and i am assuming that you used the correct brake fluid ,,
Old Sep 30, 2020 | 12:29 AM
Thanks for the help replaced both front brake hoses and drove it the longer than before and not issue so far.
Old Oct 12, 2020 | 04:03 PM
Brakes are still locking up both front calipers lock up. Drives fine them then all of the sudden the lock up getting worse the hotter it gets. Its got to be something either with master cylinder or abs I don't know.
Old Oct 12, 2020 | 04:45 PM
Have you check to make sure it's not the caliper that's locking up to being over heated because the hoses were bad for too long. Take the caliper off and press them in to see if it's hard.
