2000 Rear Light Issue
I just bought a 2000 Honda Accord 2dr V6... I am also having a brake light issue.. all of the lights work... including the rear window brake light... but the other brake lights are not working. Replaced the bulbs and the fuse under the hood. Still nothing. Any suggestions??
Edit: I moved this to a thread of its own as your car is different and sounds like a different issue than the one you posted in. Also....welcome to HAF
Thank you Poorman for responding... sorry it took so long for me to get back on.. the lights come on when the headlights and running lights are on... they just dont come on when I push the brake pedal... however, the 3rd brake light does.????
Check the number 9 (7.5A) fuse located in the driver's side fuse box too.
If that is okay, examine the wires and connector on the brake light failure sensor (located on the left rear of the trunk). While you're at it, check the ground connection (G601) near there too.
