2000 Rear Light Issue
Old Apr 16, 2013 | 06:36 PM
Yes, need a tester. The fact the center light works means the brake switch is good. On this gen/model the "outer brake" lights go thru the failure sensor but not the center/high mount light - it comes straight from the switch ???
The outer lights do share a common ground (G601) so that is in "play" as well. So knowing if there is good ground and then knowing is there is power (12v) on the green wire out of the failure sensor will be the next step.
Old Apr 17, 2013 | 09:04 AM
LisaG's Avatar
It was a loose wire coming out of the little box in back... its working now... thank you all!!
Bobpt
Jul 21, 2012 09:55 AM
94ex915
Jul 19, 2012 07:46 PM
SC Tiger
Jul 11, 2011 09:15 PM
kubafle
Aug 17, 2010 06:51 AM
