2000 v6 vtec exv6
Old May 12, 2019 | 08:11 AM
dsmithh's Avatar
Default 2000 v6 vtec exv6
I’ve got a P1259 code and changed the oil yesterday with no change in the code reading. I’d like to do some more troubleshooting, but I cannot find a good picture of just where this device is located. Depending on where it is, will determine if I can proceed. Thanks very much for any suggestions and tips!
Old May 12, 2019 | 11:09 PM
V6 supplemental manual is at this link: http://www.gvrdeu.org/Honda%20FSM/Ac...0SM%20Supp.pdf
Chapter 6-6 includes the DTC troubleshooting for P1259. DTC P1259: A problem in the VTEC Oil Pressure Switch circuit or VTEC Solenoid Valve circuit
The VTEC solenoid valve is part of the oil filter assembly. The VTEC solenoid valve filter/screen can be cleaned. See Chapter 6-9.
Here are images of the VTEC oil pressure switch and the VTEC solenoid valve connector.
jtriggy
Sep 26, 2010 11:33 PM
MontrealJohn
Aug 6, 2010 06:27 AM
03v6accord
Mar 1, 2010 09:38 AM
LEOJAPAN1
Feb 12, 2010 03:13 PM
GOH10 Runner
Mar 3, 2007 01:01 PM
