2001 Accord A/C Help
Old Jun 14, 2010 | 10:12 PM
SidBrook's Avatar
Default 2001 Accord A/C Help
Hey guys,
Any help would be greatly appreciated. I have a 2001 Honda Accord Coupe. The AC will no longer turn on. The Compressor is turning. If I turn the AC on and crank the setting to maximum, hot air will eventually blow out from the vents. Thinking that I need to recharge, I put a gauge on the Low Port Side and the reading is 95 while the AC is on. From what I remember, that is way too high. Any thoughts? I really want to avoid putting a lot of money into this car. Any chance this is something simple that I missed?
Thanks
Old Jun 15, 2010 | 12:28 AM
deserthonda's Avatar
i would chk the freon level first ..........hook up a set of a/c gauges and see what the pressures are at ..if hardly any freon in system, you need to evacuate put system under vacuum and recharge system ,, install some tracer dye so you will be able to tell where leak is at , you will need a special light and glasses to see the dye properly ,,
mamtsberg
Mar 17, 2010 09:15 PM
new2honda
Jan 31, 2007 02:36 PM
kwp1229
Sep 22, 2005 04:57 PM
rhinotechie
Aug 7, 2005 09:45 PM
ryan ortego
May 19, 2005 06:06 PM
