2001 Accord engine code P1108
got me this car and it have this code , try to clear it but as soon i start the engine it popup again, also when i'm driving it stall and die after a few minutes, replace fuel pump and coil in the distribuitos and stil does it
thanks for any help or advice i can get in this issue
P1108 is a code for the BARO sensor that is part of the PCM and is not a replacable part. You can try resetting the PCM by pullng the backup/radio fuse in the engine bay fuse box to reset. Then check for codes again. Please verify the code is P1108.
If you P1108 returns, then you'll need to replace the PCM. I'd probably go with a used part from a junkyard or ebay as a new PCM is expensive. You'll also have to get the PCM programmed to recognize your key to start the vehicle.
Jason2kim
Mar 5, 2009 04:54 PM
