2001 Accord V6 A/C Hose Replacement
Old May 6, 2013 | 09:48 AM
VonBorakus's Avatar
Default 2001 Accord V6 A/C Hose Replacement
Hey Everyone,
I just joined this board after referral from a friend!
My fiance has a 2001 accord with the vtec v6, recently her AC stopped blowing cold air. I opened the engine bay and discovered the hose had rubbed against the radiator fan shroud and created a large hole in it.
I believe the hose to be part #80311-S87-A02 which is listed as a suction hose.
My question is, how much work is this to replace on my own. I've not done work on Hondas before. I have however, replaced A/C hoses on my Subaru before.
I'm assuming since the hole is sizeable all the coolant has leaked from the system so I shouldn't have to get it evacuated first right?
I should be able to replace the hose and get it recharged at a shop correct?
Any other advice or pointers would be much appreciated. Thanks!
Old May 6, 2013 | 07:42 PM
Me, I'm poor. There are compression fittings that can "repair" metal ac lines.
If the line has a hole in it...suggest a new drier - add the proper amount of oil back into the system _ 3 oz or so, check the manual - pull a vac. Doing this helps "burn" off and water that got into the system. Then be sure it holds the vac.....if not there is still a leak. Then charge the system.
Old May 7, 2013 | 02:09 PM
VonBorakus's Avatar
Thanks!
I think this hole is too large to be patched using that method but I would be interested in trying it!
Apparently this line is "uncreachable" seems like I can reach it by taking the radiator shroud off. Has anyone done this on their own before?
Old May 8, 2013 | 08:17 PM
Got a pic of the line...again trying to know which one we are talking about.
Also, unless the hose cut thru more than ~ 1/4 inch of the line - length wise - the "splice repair" is an option.
Old May 9, 2013 | 08:37 AM
VonBorakus's Avatar
I snapped a quick picture, hopefully you can see the issue! Sorry if its not sized properly. I circled the point where the hose is punctured.
Old May 10, 2013 | 06:17 PM
Sorry, I can't open the pic?
gcmlfm
Jul 5, 2012 08:25 PM
jamesejam
Sep 21, 2009 02:37 PM
Wilsco
Nov 20, 2006 05:53 PM
newwct
Sep 19, 2006 10:37 PM
Bobby W
Jun 30, 2006 12:15 PM
