2001 Cluth not disengaging properly
Old Oct 16, 2012 | 09:20 PM
wupah's Avatar
Default 2001 Cluth not disengaging properly
Hey,
So my clutch doesn't fully disengage anymore. At a complete stop I can't put it in gear anymore unless I pump the clutch a couple of times and then out of the blue it lets me put it in gear.
-And when im in gear coming to a stop, with the clutch as far down as it can go, the clutch remains engaged.
-I tried adjusting the little lever in the driver's footwell but the **** that attaches to the pedal is extended as far as It can go.
-Fluid level is good and the master was replaced last year.
-I was thinking of trying to bleed the master ?
any help is appreciated !
Old Oct 17, 2012 | 06:50 AM
Bleed the clutch system, it really sounds like you got air in the hydraulic line.
But first it's important to restore the proper adjustment to the pedal pushrod. The master cylinder MUST return to it's proper position in order to vent back to the reservoir - that's important for auto-adjustment as the clutch disk wears out.
Old Oct 17, 2012 | 11:14 AM
wupah's Avatar
I'll try bleeding it tonight, any advice on how to adjust the pedal pushrod properly ?
I looked around, and it seems like the slave failing shortly after a MC replacement is quite common.
car has 180k miles..
Old Oct 17, 2012 | 12:23 PM
There's a shop manual you can download. Sticky thread in Gen.Tech. about "common DIY" links; there should be one link about manuals.
As far as slave failure, about the only way a slave cylinder can fail results in fluid leaking out. It's only the master that can fail in a way that allows fluid to leak back into the reservoir.
Old Oct 20, 2012 | 10:01 AM
wupah's Avatar
Turns out it was a broken clutch spring causing it to not disengage fully. Sadly it was an expensive repair.
Old Oct 21, 2012 | 09:15 PM
Wow, that's a bit unusual, but thanks for posting the end of the story.
Happened to me a long time ago in a 72 Datsun. One of the dampening springs in the hub of the clutch disk broke, wedging itself between the clutch, flywheel, & pressure plate. It was all locked up & would not disengage at all. I didn't think of that because mine didn't disengage at all.
Cateastrophe
Feb 8, 2013 06:56 AM
kosei
Jun 10, 2009 03:11 PM
ecko
Apr 17, 2009 04:45 PM
has1014
Dec 7, 2008 06:06 PM
06accord
Feb 20, 2007 11:42 AM
