2001 EX-Airflow Only On Drivers Side
Old May 1, 2013 | 05:15 PM
Milanodan's Avatar
Default 2001 EX-Airflow Only On Drivers Side
No air comes out of center or passenger side vents. Help!
Old May 2, 2013 | 06:21 PM
Well at least you are staying cool
Now to the question - Do you have auto HVAC or Manual HVAC? Or another way of asking, do you set the temp to a certain temp - like your house HVAC. Or is there just a **** that you set to a hot/cold setting.
Old May 2, 2013 | 07:03 PM
Milanodan's Avatar
Thanks! The car has the manual HVAC, with up and down arrows for the temp you want. It used to work fine, then I put the car in my garage for ~6 months. Some hose must have cracked/fallen off or an air door is stuck.
Old May 3, 2013 | 06:01 PM
That sound smore like the auto HVAC.
This pic is for "manual HVAC" controls.....the **** to the right is the hot/cold "setter"
Attached Thumbnails 2001 EX-Airflow Only On Drivers Side-6th-manual-ac-controls.jpg
Old May 3, 2013 | 06:06 PM
This is the "auto HVAC", note the "auto" on the ****.
Attached Thumbnails 2001 EX-Airflow Only On Drivers Side-6th-gen-hvac-auto-dtc.jpg
Old May 3, 2013 | 09:11 PM
Milanodan's Avatar
You're correct, it is the "Auto" version. Wifes car, wasn't here when I sent last message.
Old May 4, 2013 | 09:41 AM
In the pic for the "auto" AC - the procedure for checking for HVAC codes is included. Please check the codes as it lists.
I'm guessing one of the mode or mix motors but want to check the codes first.
Old May 5, 2013 | 02:29 PM
Milanodan's Avatar
Did the check--NO codes set.
Old May 6, 2013 | 05:46 PM
Again just want to be sure......no air flow out of the center or right vents......vs. the temp in the center or right vents is not cool/hot.
Sorry, just wanting to know. If air is moving out the pass/right vent yet not cold or hot that is one path.....No air moving out of the pass/right vent that is another.
Old May 6, 2013 | 07:19 PM
Milanodan's Avatar
Thanks. No airflow from the center and pass. vents.
