2002 Accord Distributor Rotor Question
Old Sep 1, 2009 | 10:34 AM
krussov
Default 2002 Accord Distributor Rotor Question
Hi all,
I'm about to replace my spark plugs and along with it my distributor rotor. Does anybody know whether the 02 accord (4 cyl, manual) uses a Tec or Apache type? Thanks in advance.
Old Sep 1, 2009 | 04:55 PM
finch13's Avatar
That's something you'll have to look into on the distributor. I'm pretty sure Honda stopped using 2 different types of distributors in 1998. If they are different, a parts store should be able to determine which one it is based on the engine code, it's stamped right below or around the upper coolant hose on the block.
F23A1 - VTEC 4cyl LX/EX
F23A4 - ULEV VTEC 4cyl LX/EX
F23A5 - non-VTEC 4cyl DX
Old Sep 1, 2009 | 05:23 PM
Go to www dot hondaautomotiveparts dot com
click PARTS
put in your car's information
Look at the 2 different distributor pictures, which one matches YOURS?
Old Sep 2, 2009 | 03:07 PM
krussov
Thanks for the input guys. '02 Accord EX Coupe has a HITACHI distributor just as an FYI for everyone else.
Old Sep 2, 2009 | 03:42 PM
For everyone else, I bet it's random since they're probably BOTH used. Honda normally has more than one supplier for most things, and occasionally they're not absolutely identical.
chingalong
May 26, 2011 11:14 PM
llcookej
Dec 8, 2010 11:15 PM
my93beater
Sep 24, 2010 10:16 AM
ranma21
Oct 21, 2008 12:23 AM
ranma21
Oct 21, 2008 12:21 AM
