2002 accord p1457 code
Old Jul 28, 2011 | 12:15 PM
jasona68's Avatar
Post 2002 accord p1457 code
Ok, here's my issue... I bought my 02 Accord EX had it a month and started getting trouble code p1457 evap system leak. I can clear the code and within 3 days it will be back. I tried a new factory full cap. I am looking for guidence, point me in a direction.
Old Jul 28, 2011 | 06:51 PM
Check evap cannister, vent shut valve, and hoses to same. You'll need a shop manual to perform correct diagnostics. Suggest an emanual from automanualsource on ebay, $21.99.
Old Jul 28, 2011 | 08:32 PM
piggylover1985's Avatar
You can also go to a shop and have them smoke test it and find where the smoke leak out, then there's your leak. Could be the gas cap, vent shut of valve and solenoid.
Old Jul 28, 2011 | 08:57 PM
It may be the evap bypass solenoid valve. Refer to TSB:
s2ki.com/stor/library/TSB/a03-001.pdf
Old Jul 28, 2011 | 09:04 PM
P1456 would be the code if it was your gas cap, or the fuel tank.
P1457 is for the canister system. Read this post.
https://www.hondaaccordforum.com/for...-1999-a-27179/
Old Sep 10, 2011 | 06:22 PM
jasona68's Avatar
Post update
Here's an update. So I put in a vent shut valve and a new canister, together they were like 58 bucks and some change. My local dealer even stocks them. Things had been fine until today, I got the code again. I think my next step is to put a bypass valve in.
Old Dec 3, 2011 | 11:06 PM
jasona68's Avatar
Final update.
It has been 5 weeks and no code, I'm sure I got it taken care of. Redbull-1 you were right. After putting in a Bypass Solenoid I have not had any problems. Cost was $79 at the dealership.
Old Dec 3, 2011 | 11:09 PM
jasona68's Avatar
Thank You for the responses. This forum helped more than the dealership did!
Old Dec 9, 2011 | 03:37 PM
jfidelh's Avatar
I got code 90(1456/1457) but have no way of seeing which it is. Im going to buy the bypass solenoid valve and if that doesnt do it im going to return it. Hopefully it does.
Old Dec 12, 2011 | 01:13 PM
jfidelh's Avatar
I just replaced the vent shut valve in my car, Ill post an update later myself to see if that fixed it.
