2002 accord p1457 code
Old Oct 11, 2012 | 03:58 AM
jfidelh's Avatar
10 months later and still have the damn code! I replaced the vent shut valve located on the canister last year and nothing! so im back at it again trying to get this code out of my life!
Old Oct 11, 2012 | 08:29 AM
So when you removed that valve, did you check it by applying battery voltage? I wouldn't replace a valve just because that was the one that failed on someone else's car. When this happened to me, I took off a couple valves until I found one that was NOT working.
I think you said you got code 90 but didn't get the OBD-2 code (1456 vs. 1457). Still true? If so, then you might even be looking at a bad gasket on your gas cap. Or a bad gasket on the fuel tank (fuelpump installation flange). You can narrow down your search by getting the OBD-2 code.
4mfrance
Apr 28, 2012 08:07 PM
amdfan
Aug 29, 2011 07:32 AM
Moddage
Oct 19, 2009 12:45 PM
jeffk14
Sep 3, 2009 08:54 PM
bigant
Dec 2, 2008 04:10 AM
