2002 Honda accord Check Engine Light is on!
Old Feb 10, 2011 | 06:50 AM
Well I'm a manual-trans guy so not an expert on auto. But I think getting rid of old dirty fluid in there is more likely to help things.
We'll see if any auto-trans guys chime in.
Old Feb 10, 2011 | 12:00 PM
You can find anecdotal evidence for just about any position. I have never seen anything to suggest that drain/refill will damage a working transmission. If you're already having problems and perform a drain/replace, to be followed by failure of the transmission, it is not an indictment of transmission service.
ATF fluid is circulated very fast iin transmission. You will empty the reservoir (2-3 qts) in less than 30 secs. So once you're driving the fluid is rotated into/out of the torque converter frequently, where it get very thoroughly mixed. I would think a 5-10 minute drive will blend old/new fluid completely. It won't hurt to drive 50-100 miles before another drain/swap.
Old Feb 11, 2011 | 08:27 AM
Billy's Avatar
Thanks Texas! I will try to do another drain and refill asap. Just feel some slipping when car shift. And, I am wondering, I feel that my car slipping worse in cold weather(before the engine totally warmed up). is this normal?
Old Feb 12, 2011 | 08:38 AM
Billy's Avatar
So, adlerrogers, your 02 honda also had the CEL problem? How did you fix it? I am thinking of checking and cleaning the fuel injector and checking the wiring of my 02 sensor. But on the internet, they said a cleaning injector system(machine) is needed for this work. Anyone know that machine is necessary or not?
Old Feb 12, 2011 | 11:46 AM
As far as cleaning the injectors, I'd get a bottle of Chevron Techron (or your favorite brand of stuff) and pour into the fuel tank. It's getting more & more rare for injectors to actually need more than that.
Old Mar 10, 2013 | 04:35 AM
Tracy Ortiz's Avatar
Default tracy
Hi I have a 2002 Honda Accord EX with 280,000 I have kept this car in immaculate shape and as i was driving yesterday my check engine light came on. I checked to see if I was low on oil because this had happened to me before but than again it has been like 3 or 4 months since i got an oil change. i was low on oil so I added oil which I always use 5W-20. The light still has not gone off. Any suggestions?
Old Mar 10, 2013 | 09:22 AM
  #17
Many parts stores will check the codes for free. Get the actual code (not their description), it will begin with "P" and then four digits.
Old Mar 11, 2013 | 07:27 AM
  #18
And let us know whether it's a V-6 or 4-cyl; also automatic/manual transmission.
Cairn terrier
Jan 30, 2015 02:25 PM
thoram
Jul 30, 2012 08:27 PM
corporategohan
Feb 20, 2009 10:22 AM
calspud
Oct 28, 2007 12:59 PM
