2002 Honda Accord LX V6 fuel pump pigtail wiring diagram.
Old Nov 12, 2024 | 10:09 AM
Zchamberss01's Avatar
Question 2002 Honda Accord LX V6 fuel pump pigtail wiring diagram.
I can't find any sign of a reliable diagram online at all, I need to know each individual wires correlation to the pins on the relay. I'm bypassing the base system because I must have a short somewhere that's preventing the relay from sending power to the fuel pump. Any help at all would be great, thank you.
Old Nov 15, 2024 | 06:28 PM
Moved your post to gen tech help where you'll get more answers.
Bypassing isn't a great idea as you can cause unintended consequences.
What is the exact issue you are facing and what have you tested/your results so far?
Just trying to make sure you have the same wire colors/numbers based on the shop manual.
The main fuel relay connector wire numbers are:
12x3
4567
1 grn/yel
2 blu/orn
3 blk
4 yel/blk
5 red/wht
6 blk/yel
7 wht/grn
Old Nov 15, 2024 | 06:59 PM
nomad2020's Avatar
you probably did all this but did you chk the fuses? are you getting power into the relay ., if power in and not out might be a bad relay
as for the short if you have a short on the power side it would blow a fuse
Like PA said bypassing is not a good idea ,, (my advise for what is worth ) chk all related things starting at fuse and do the eliminating process
Old Nov 18, 2024 | 06:58 AM
Hey thanks for the response I appreciate the help, yes I've checked all fuses and relay over and over, replaced the relay now 3 times because that's what I originally assumed the problem was. I actually ended up figuring it out though, turns out I have a bad ground on the harness side, I ran a ground directly through the relay/harness and ran it back to the fuel pump ground and just secured them together. It's starting and driving great now.
Old Nov 18, 2024 | 06:59 AM
Thank you so much for your help it's appreciated. I ended up figuring it out, it was a bad ground on harness side, ran one directly into the harness/relay and ran it back to the fuel pump ground and secured them together. It's running great now.
wal
Dec 7, 2010 06:41 PM
hondabuyer
Sep 17, 2009 10:12 AM
Jmoney
Aug 4, 2009 06:38 AM
HondaAccord93
Mar 18, 2009 08:40 PM
davidl
Oct 22, 2008 08:33 PM
