2002 Honda V6 Check Engine and TCS Lights
Old Oct 18, 2007 | 12:39 PM
calspud
Default 2002 Honda V6 Check Engine and TCS Lights
I have a 2002 EX V6 4-Door sedan with less than 74,000 miles that produceda Check Engine light with code P0133 (sensor 1 bank 1 slow to respond). I replaced the O2 sensor with a factory part. The Check Engine light returned 4 days later with an occasionalTCS Light and I noticed rough cold starts but ran quite well after warm-up. I brought it to the only localdealer who charged me $109 and said it would cost $2683 plus tax to start finding the solution (no guarantee it would fix the car).
They found P0301 & P0304 (misfire cylinders 1 & 4) and TCS code 32-1 (front out solenoid failure) found MAP sensor voltage low. They advised starting with a valve adjustment and check camshaft for wear, replacing the fuel injectors, and replacing spark plugs to start eliminating possible causes for the Check Engine Light. For the TCS/ABS code 32-1,found voltage in and out of control unit ok. Circuit is not shorted to ground or open so they advised replacing ABS Modulator/Control Unit.
I brought is to an independent mechanic who thought it just needed a tune-up (for the CEL) and he checked the plug boots for cracks etc.. No improvement so the car was brought back a week later. He found the EGR port clogged with carbon and cleaned it out. The engine ran notably smoother and the CEL went out for another 3 days. The Check Engine Light returned with the TCS and now occasionally when I come to a stop the red brake light will illuminate until I let off the brake. The independent is now stumped and he is thinking it needs a valve adjustment because the valves are too tight - possibly stretched! I barely know enough to be dangerous but wouldn't that case worsen as the engine got hot and run better on a cold start?
Any suggestions would be appreciated!
Old Oct 18, 2007 | 02:14 PM
deserthonda's Avatar
Default RE: 2002 Honda V6 Check Engine and TCS Lights
ORIGINAL: calspud
I have a 2002 EX V6 4-Door sedan with less than 74,000 miles that I brought it to the only localdealer who charged me $109 and said it would cost $2683 plus tax to start finding the solution (no guarantee it would fix the car).
Wow , no guarantee so what are they going to do for the money ???
TCS code 32 is not the frt solenoid failure , that is the ABS CODE 32
TCS CODE 32 IS FOR ENGINE SPEED SIGNAL,
which makes sense if your car is misfiring .
they need to spend some more time to diagnose the issue properly instead of guessing and giving you such ridiclous estimates
Old Oct 18, 2007 | 02:38 PM
00AccordLX5spd's Avatar
Registered User
Are they a Honda dealer? If so, you should call Honda of America and tell them exactly what you told us the dealership said. That is absolutely absurd.
Old Oct 21, 2007 | 01:44 AM
calspud
Honda of America returned my call after two days and said they don't understand what my problem is. If the dealership diagnosis a problem, then they are the technical experts and Honda of America is not capable of dealing with technical questions. They suggested I just allow the dealership to perform the work or bring the car to another Honda dealership to diagnos the car and pay another $109.
Old Oct 28, 2007 | 12:59 PM
calspud
Just thought I would post the results to help someone else that experiences similar problems - It apparently was 4 clogged fuel injectors. Running 4 or 5 tanks of SeaFoam and Berryman's injector cleaner did not help. I cant prove that I got some bad fuel or that I buy from a place that sells inferior fuel but replacing 4 of the injectors has fixed the engine light and TCS light so far. I have been purchasing fuel from Costco for the past 2 years and the independant mechanic that worked on this problem suggested buy fuel from a better source. So far the total has been around $1100.
I am hoping that the TCS light does not come back on because apparently that will require replacing the brake module/controller which is another $1500.
Your decision on where to purchase your fuelmay become very costly!
csh217
Apr 30, 2013 09:03 PM
rahulmunjal
Feb 27, 2012 12:10 PM
aspringer210
Feb 26, 2012 07:35 PM
Jgams
Oct 9, 2010 04:09 PM
Dj Insanity
May 21, 2007 10:05 PM
