2003 Accord A/C Troubleshooting
Old May 9, 2011 | 01:36 PM
drdavidge's Avatar
Default 2003 Accord A/C Troubleshooting
Hey guys.. my girl has a 2003 Accord EX and the A/C isn't working. The blower fans work, all the lights come on, but the air isn't cold. What steps should I go through to diagnose the problem? Should I go ahead and replace the relay as a cheap attempt? As far as I can tell, it doesn't sound like the compressor is turning on.. no change in engine sound when turning it on/off.
Old May 9, 2011 | 01:59 PM
You should do some diagnostics first.
Start the engine and watch the plate in front of the a/c compressor pulley. It should not spin with the pulley. Turn on the a/c and see if that plate spins with the pulley. Also see if both fans on the radiator turn on when you turn on the a/c.
Old May 9, 2011 | 04:07 PM
drdavidge's Avatar
Thanks. Is that the left-most part of #9 / the part next to #8?
What else should I look for after that?
Old May 9, 2011 | 05:56 PM
That is the correct part.
The next step depends on what you find in the first step.
Old May 10, 2011 | 09:06 AM
drdavidge's Avatar
Thanks. After I see the car today I might not be around it again until Saturday. Anything else I should look at today while I am around based on what happens with the outside plate?
Old May 10, 2011 | 11:20 AM
If the plate doesn't move, then unplug the electrical connector to the compressor, then see if you get voltage to the compressor.
In the DIY section, there is a writeup on how to get HVAC codes that may help you.
Old May 12, 2011 | 07:50 AM
drdavidge's Avatar
So I was able to take a quick look yesterday. The placement of the compressor makes it hard to get a good look at that outside plate. I was able to see just the edge of it from looking at it from the top (see picture below). This particular piece didn't spin regardless of the a/c button being on or off, but I am hoping this was the part I should have been looking at. Can you confirm?
Old May 12, 2011 | 09:55 AM
The next step is to figure out if you are getting power to the compressor. Just unplug the compressor and use a volt meter to see if the electrical connector to the compressor is getting power when the a/c is turned on while the engine is running.
CrawDaddy
Jan 11, 2012 12:08 AM
osanyin
Dec 4, 2011 01:23 PM
Pilot
Sep 8, 2011 03:32 PM
ejcr032
Mar 15, 2011 04:35 PM
civaccord29
Feb 26, 2010 03:56 PM
