2003 Accord DEAD !!!
More information necessary.
Does engine turn over slowly or nothing? Can you hear a "click" when you turn the key?
Does oil, Check Engine Light come on when you turn keyswitch to ON? If not, dead battery or badly corroded battery cables seems likely.
Brake pedal will be firmer w/o power boost from engine running. Wheels harder to turn is correct w/o engine running and power steering boost.
No it doesnt even make the CLICK sound too.
The engine and battery light and other indicators comes on n goes off immideately as it does when you start normally, but this thing stays and doesnt switch off.
is this too bad?
Thnkx
is this too bad?
Thnkx
It could be a faulty starter, ignition switch or bad battery. Remove battery and have checked/charged if necessary. If battery is good, ignition switch is most likely suspect. It is not providing enabling voltage to the starter, or starter solenoid has gone open (unlikely but possible). You can check the starter solenoid drive wire for 12V when keyswitch is turned to Start to determine if keyswitch or starter.
Address no-start first, and then have a scan performed to see what engine code is set, unless you have a scanner to extract the code.
ORIGINAL: Tippman7641
Maybe the chip in the key got damaged and since if its not reading it wont work, try a different key you have
tpstaples
Oct 5, 2021 05:53 AM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
yousef
Apr 22, 2009 10:40 PM
