2003 Accord DEAD !!!
Old Oct 12, 2008 | 01:13 AM
souls6e
Default 2003 Accord DEAD !!!
Hi All, the car was fine when i drove it to the mall, came back and it wont start nor does it make the cranking noise. The wheels n brakes are a lot harder guess jammed. Could this be the anti theft problem???
Thnks
Old Oct 12, 2008 | 06:17 AM
Default RE: 2003 Accord DEAD !!!
More information necessary.
Does engine turn over slowly or nothing? Can you hear a "click" when you turn the key?
Does oil, Check Engine Light come on when you turn keyswitch to ON? If not, dead battery or badly corroded battery cables seems likely.
Brake pedal will be firmer w/o power boost from engine running. Wheels harder to turn is correct w/o engine running and power steering boost.
Old Oct 12, 2008 | 10:21 AM
souls6e
No it doesnt even make the CLICK sound too.
The engine and battery light and other indicators comes on n goes off immideately as it does when you start normally, but this thing stays and doesnt switch off.
is this too bad?
Thnkx
Old Oct 12, 2008 | 10:28 AM
Check battery and battery connections. Charge, clean, or replace as indicated.
Is "thing" an orange light w/ picture of engine?
Old Oct 12, 2008 | 12:01 PM
souls6e
The battery connections all look ok.
Yes it is the Engine Light.
Thnkx
Old Oct 12, 2008 | 06:08 PM
It could be a faulty starter, ignition switch or bad battery. Remove battery and have checked/charged if necessary. If battery is good, ignition switch is most likely suspect. It is not providing enabling voltage to the starter, or starter solenoid has gone open (unlikely but possible). You can check the starter solenoid drive wire for 12V when keyswitch is turned to Start to determine if keyswitch or starter.
Address no-start first, and then have a scan performed to see what engine code is set, unless you have a scanner to extract the code.
Old Oct 12, 2008 | 06:49 PM
Tippman7641's Avatar
mabe the chip in the key got damaged and sinces if its not reading it wont work, try a different key you have
Old Oct 12, 2008 | 09:24 PM
Vipers4Life's Avatar
ORIGINAL: Tippman7641
Maybe the chip in the key got damaged and since if its not reading it wont work, try a different key you have
That was an issue with me. I bought the car and it had like 2 or 3 spares. Like the first day all I used was the main key. My dad went to use the spare and they didn't work. He had to get new spares and they all worked.
Old Oct 13, 2008 | 09:51 AM
It does not sound like animmobilizer problem(chip in the key). If it were,the starter motor would work but the engine would not start.
Old Oct 14, 2008 | 10:18 PM
souls6e
Finally got it Fixed at the dealership, THE PROBLEM WAS "DEAD BATTERY" which i did not expect. Atleast it was not a back breaking expense.
Thank you all for your time and help !!!
S.
tpstaples
Oct 5, 2021 05:53 AM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
yousef
Apr 22, 2009 10:40 PM
DaveyJfbe
Aug 16, 2007 05:59 PM
