2003 accord LX a/c problem
Old May 26, 2010 | 10:08 AM
Wing301's Avatar
Default 2003 accord LX a/c problem
i resent bought a used 03 accord LX 4 cyl sedan with about 110k miles it runs great but the AC recently stopped working it was running fine then turned of the car for about 20 mins and when i turned it on again it stopped working.
1. the blower does not turn on at all but it works i connected it straight to the battery and it works fine
2. all the fuses and relays seem to be in working order
3. the compressor clutch turn on for like 2 secs then dis engages
my friend looked at and suspects that it could be the car is low on freon and the car has a low pressure cutout so the ac wont turn on if the freon is too low
if this is the issue how can i refill the refrigerant if the compressor wont stay on it need to suck in the refrigerant how would i bypass the low pressure cut out?
Old May 26, 2010 | 02:41 PM
Wing301's Avatar
also there was a broke fuse that was labeled "front acc socket" i fixed it didnt seem to do anything it was a 7.5v fuse
Old May 27, 2010 | 12:10 AM
kris_loehr's Avatar
You should be able to add Freon without problem but the question is how much to put in. I just replaced the compressor on my 2003 Accord today and no problem changing it. My coupe only holds about a can and half of Freon.
Old May 27, 2010 | 11:48 AM
Wing301's Avatar
well i took the car today to get the AC inspected apparently the whole AC control unit went out they checked all the part and everything runs good but the ac control unit isnt communicating with the system so they told me it will cost 80 for installion in labor but over $400 in parts!!!!! so my question is would i be better off buyin the parts myself and letting them install it?
Old May 27, 2010 | 11:51 AM
Pros & cons about that...
Shop may not warranty the parts unless you buy from them.
Shop may charge a higher labor rate to make up for the lost profits from parts.
So you may or may not come out ahead.
Old May 27, 2010 | 12:05 PM
Wing301's Avatar
well the shop told me they will charge the same if i bring in the parts my self
would honda be able to help me at all even tho im out of warranty i bought the car as is
Old May 27, 2010 | 12:32 PM
Wing301's Avatar
so looking online is this the unit that they need?
http://cgi.ebay.com/ebaymotors/ws/eB...8815&viewitem=
Old May 27, 2010 | 01:01 PM
I expect it's too far out of warranty so Honda wouldn't do anything, but I don't know that for sure. I've heard of them doing things when it's "close" and you're doing the work at a dealer.
Old May 28, 2010 | 02:33 PM
Wing301's Avatar
i think i might have found a cheaper solution with a possible plus
http://www.installer.com/item/displa...php?it=99-7864
its an aftermarket radio housing kit that has the hvac controls! maybe the AC controls on this can replace the defective one on my current dash unit plus i get to install my own aftermarket radio (with a nice ipod compatibility)
would this be a good alternative?
Old Jun 1, 2010 | 11:02 AM
Sounds like a cool idea. Whether THAT unit is any good I have no clue. Post that question over in the A/V Electronics area where they might know??
