2003 Accord P0010 code
Old Jun 13, 2017 | 07:09 AM
Legacy11's Avatar
Default 2003 Accord P0010 code
Car is a 2003 Accord 4 cylinder. Started dropping the P0010 code recently. I can clear the code and it will not reappear when the car is started and sits idling but once I start driving the code will drop when I hit about 10 mph. I've pulled the oil control solenoid valve and it checks outs ok. Oil screen (VTC filter) is clean. Wiring looks find, although I haven't traced it back to the PCM to verify no breaks in the wires. If I had a bad wire I would expect the code to drop as soon as the engine is running.
Any suggestions regarding what might be causing the problem?
Thanks
Old Jun 13, 2017 | 08:33 AM
See attached diagnostic. First steps suggest code does not appear immediately.
File Type: pdf
Old Jun 14, 2017 | 05:08 AM
Legacy11's Avatar
Thanks much for the info. Guess I will have to trace the wires back to the PCM next when I get a chance
Thanks again.
Khai Son
Mar 14, 2012 11:32 PM
Rtherres
Jan 30, 2011 04:58 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
