2003 EX 4cyl Code P0303
Old Sep 15, 2025 | 01:48 PM
JulieG73's Avatar
Default 2003 EX 4cyl Code P0303
2003 Honda accord ex 4-cylinder - 161,000 miles.
Code p0303. Engine runs rough and feels like it is going to stall. Scanner indicates cylinder 3 misfire.
Scanner shows the following:
P0303
01/02
P0303
02/02
Fault 01
Pend 01
What am I looking at here and what is usually the main culprit? Thanks.
Old Sep 16, 2025 | 11:30 PM
Since the misfire is specific to cylinder 3, then the issues could be the cylinder 3 coil, spark plug, fuel injector, or valve/piston issue. Quickest test to eliminate one is to swap coil 3 and coil 4. If the misfire moves to cylinder 4, then coil is likely culprit. If it stays at cylinder 3, then swap spark plug with cylinder 2. See if the misfire moves to cyl 2 or remains. The fuel injector is probably the hardest item to swap, so try that last if the misfire remains on cyl 3.
JulieG73
Sep 2, 2020 12:01 PM
Legacy11
Jun 14, 2017 05:08 AM
DON CHEDA
Sep 26, 2010 09:18 AM
beckster
Jul 19, 2010 05:23 PM
