2003 EX Passenger Side Turn Signal Not Working
Old Jun 24, 2020 | 03:33 PM
JulieG73's Avatar
Default 2003 EX Passenger Side Turn Signal Not Working
2003 passenger side turn signal is not working front or rear, Hazard flasher only works on drivers side. Bulbs are good. Please advise, thanks.
Old Jun 24, 2020 | 05:25 PM
Have you done any recent work on the car not long before you had this issue?
So only the driver's side is working when using either the turn signals or the hazards?
If yes, then I suspect a faulty turn signal/flasher relay that is located in the under dash fuse box. You may have to remove a plastic trim panel to access the relays.
The issue could be something else in the electrical system. If you want to be 100%, you could do some electrical testing that can verify you have an issue on the part of the turn signal flasher feeding the passenger side of the vehicle.
hondadriver08
Jan 24, 2014 06:38 AM
rslayback
Feb 25, 2010 07:08 AM
rtsulliv4801
Feb 4, 2009 05:33 PM
kennilope
Mar 1, 2007 08:15 PM
