sider marker turn signal not working
Old Feb 27, 2007 | 09:02 PM
kennilope's Avatar
Default sider marker turn signal not working
Honda Accord 94 EX.
the corner side markers turn signal is not working. It won't light up and wont have turn signal. All other turn signals are working fine. (bummper & tail signal). this happen for both side. Does anybody know what is going on???
i check for fuse all seem to be working... Am i short circuit at some point???
thanks
Old Feb 28, 2007 | 12:48 AM
hondadude's Avatar
Default RE: sider marker turn signal not working
Bulbs?
Old Feb 28, 2007 | 12:54 AM
kennilope's Avatar
bulbs still working
i had alot of working bulbs i tried all of them
Old Feb 28, 2007 | 12:58 AM
hondadude's Avatar
Neither marker lights nor turn signallights?
I'll round up a schematic
EDIT; you might need to use a program to enlarge this pic.
[IMG]local://upfiles/5417/46FD384642C24BD0BB28C3217361E17F.gif[/IMG]
Old Feb 28, 2007 | 01:19 AM
wietgr's Avatar
First thing is to use a test light to ck for pwer at the sockets.
Old Feb 28, 2007 | 12:39 PM
kennilope's Avatar
let me test out with the fuse later......
but isn't that when the turn signal bulb on a honda is out the turn signal inside the dash blink very fast?
It happen when my bumper signal bulbs was broken....
But the side marker didn't make this happen... it just dint' light up...
Going to play around with it later.
Old Feb 28, 2007 | 06:01 PM
kennilope's Avatar
Here is the update on the problem
I tried to see if the fuse was the problem and it wasnt it.. i replaced the fuses.. Nothing happen
Can it be the relay? or am having a bad ground connection somewhere????
I have noticed something with my car since the side corner light singnal didn't work.. When the car is on and I dont have seat belt on.. there is a beep it go on for 4 seconds then turn off.. then it go on again.. when i put seat belt on it stop.
Then today i was driving and my seat belt was off.. then i put on turn signal to make a turn.. the beep sound came on.. after the signal light stop blinking...the beep went away...... it is the same for both left and right turn.... All of the light for signals are working... back and front (bumper)....
the only thing that doesn't work is the side marker signal light... I do have the daylight on the sidemarker and those are working.....
Any Idea?
I think I got a short somewhere or a bad grounding somewhere..... Dont even know where to look at..........
Any help would be good....
Old Mar 1, 2007 | 08:15 PM
kennilope's Avatar
Here is the update.
I went to fix it today.. and i finally get the left side to work but the right side the turn signal on the side marker is not working.
I take a multimeter and see if there is any voltage there.. nothing.....
i cut off the socket and test on the battery and it is working.
dont know what happen on the right side.
can anybody tell me what should I do?
thanks.
Gangsta101
Feb 10, 2013 01:50 AM
Pajamarama
Jun 8, 2012 08:57 AM
pmurph13
May 3, 2011 10:28 PM
Tony1M
Sep 25, 2009 07:59 PM
romspacenut
Dec 17, 2008 10:09 PM
