2003 honda accord cranking problems
Old Aug 14, 2011 | 11:19 AM
libra2458's Avatar
Default 2003 honda accord cranking problems
this just started. when my car is warm, it will crank very slow, then die, as if the battery is dead. If I let it sit a few minutes, after 2-3 tries, it will start fine.
Battery is a year old, and I had it checked yesterday. Connections were removed, terminals cleaned and re-connected.
This has only happened 3 times in the last month.
Old Aug 14, 2011 | 12:35 PM
Well cleaning the ends was the best place to start....might not come back.
IF it does this again, then I would suggest having the battery tested, yes I know it is only a year old but that does not mean that it can't be bad.
Then next on the list would be the starter...again have it tested, when doing so tell them why you are having it tested.
Old Aug 14, 2011 | 12:40 PM
libra2458's Avatar
poorman212
Battery was tested and it was good. I did not have the starter tested yet. thanks for the help. I appreciate it!!
Old Aug 14, 2011 | 01:23 PM
Opps, now that I read your post again I see that it was tested yesterday...sorry, sometimes reading gets the best of me
Again, if the cables were just cleaned the issue may have been fixed.....but you never know....a "hot" electrical motor "takes" more to get it going...so a weak/poor connection could be just enough to cause it not to work.
Old Sep 3, 2011 | 09:24 PM
libra2458's Avatar
I had the main relay tested and had a new one put in. Now the cranking problem is pretty much every time I start the car. Starter problem?????
Old Sep 4, 2011 | 06:41 AM
Sounding that way. A few things you can try yourself, if you have a voltmeter, test the voltage at the small wire when this happens.
You can pull the starter and have it tested, kind of describe the issue when you take it in. If they test it only once, it may test out fine-just like when you start the car in the morning-everything is fine.....correct?
Old Sep 4, 2011 | 10:57 AM
libra2458's Avatar
Problem is now occuring in the morning and of course, not when I had it at my mechanic!! Since it is so difficult to get to the starter, he is ordering me a new one and will test the one in the car when he is ready to put it in the new one. My fear is that if the one in the car tests ok, what then??
Ignition switch has not been tested, but car does not have any of the symptoms of a failing ignition switch. I guess I am just "lucky" that the starter hasn't died completely. My mechanic thinks I may have a "dead spot or short" in the starter and once "I get passed it trying to start the car, it (starter) kicks in".
Old Sep 4, 2011 | 11:32 AM
Yes could be the starter, please ask him to check the voltage on the small wire at the starter (when trying to start) while testing everything. Testing the voltage at the small wire will confirm that the key switch is good.
Old Sep 12, 2011 | 10:20 AM
libra2458's Avatar
UPDATE: New starter installed over the weekend. Starts great, car even rides and sounds better.
Old Sep 12, 2011 | 06:38 PM
Good to hear and THANKS for the update....we like to know how the story ends.
opaque
Apr 22, 2013 12:17 AM
hondachic
Aug 6, 2012 11:40 AM
pordlawk
Nov 28, 2011 04:54 PM
tinkerevil
Apr 23, 2011 02:52 AM
5.0stang
Jul 23, 2009 07:24 PM
