2003 Honda Accord Driverside Loa Beam bulb
Old Jun 13, 2011 | 10:06 AM
rrhonda's Avatar
Default 2003 Honda Accord Driverside Loa Beam bulb
Hi,
Driver Side low beam bulb is gone. i bought the bulb, removed the battery and am able to reach the bulb but when i try to turn and remove the bulb it does not pop out. Am i missing any thing here.
If i take it to mechanic ( i have the bulb) any idea how much he charges.
Both low beam lights were blown at the same time? Can that happen? I was able to replace the passenger side bulb in 5 min.
Appreciate any help on this.
Thx
Raj
Old Jun 13, 2011 | 06:44 PM
Well the first thing I'll ask, does the low beam you replaced work now. It is possible, kind of strange but possible for both to go close to each other.
There should be a "ring" that turns, then the buld pulls straight back.
Old Jun 13, 2011 | 07:53 PM
If the plastic piece that should turn is stuck, you can try some WD-40 to help lubricate it.
Old Jun 13, 2011 | 09:15 PM
The only part to turn is the headlight bulb, the 3 plastic tabs on the headlight bulb assembly is probably not aligned with the 3 slots in the headlight housing, which would prevent it from coming out.
Attached Thumbnails 2003 Honda Accord Driverside Loa Beam bulb-headlight.jpg
hallstevenson
Aug 8, 2013 11:27 AM
SPD-2000-HONDA-ACCORD
Mar 29, 2013 08:50 AM
kouken
Nov 11, 2007 06:48 PM
mngantung
Aug 5, 2006 02:22 PM
eckhart
May 27, 2006 07:40 PM
