2003 Honda Accord EX right Turn Signal not working?
Old Oct 17, 2015 | 11:09 AM
Jeff247's Avatar
Default 2003 Honda Accord EX right Turn Signal not working?
Is there a fuse I can check for the right turn signal and where is it? When I go to signal, the right front and back signal lights are out. I also noticed the the right dash indicator does not flash (left one does) when I put on 4 way flashers. The right exterior light doesn't flash either (but left does). So unless I can replace the fuse I probably will have to take it to a dealer.
I am asking about a fuse because I read someones account of the same problem and he said "I checked the fuse." I don't see it in the manual or Haynes book.
Thank you
Old Oct 17, 2015 | 07:35 PM
Issue may be due to a faulty turn signal/flasher relay; which is located in the driver's side under-dash fuse/relay box.
Old Oct 18, 2015 | 09:50 AM
Jeff247's Avatar
Default I agree!!
I found the same problem on another site and it seems to be fairly common for the condition I described. Just went to Advance Auto to order the part. Hope to have it tomorrow. I'll let you know! Thank you
PS- I called all the local atuo stores and no on had it in stock. NAPA and Auto Zone wanted $55, Honda dealership $22 and Advance Auto was $11 ! Was just at Advance and saw it on their computer screen and it's the same one!
Old Oct 19, 2015 | 04:46 PM
Jeff247's Avatar
Default It's fixed!
Replaced the relay ($11.87) and it works! Thank you
Old Apr 7, 2016 | 10:11 AM
Tony1M's Avatar
I have resurrected this thread because my daughter's '03 Accord is having this identical problem and I want to replace the signal relay. Because I don't have the vehicle at hand to examine the situation myself, I have just one question. How much trim, if any, do you have to remove in order to expose the relay enough to replace it?
Thanks.
Old Apr 7, 2016 | 11:03 AM
Tony1M's Avatar
Sorry. Forget my question, guys. I've already answered my own question.
hondadriver08
Jan 24, 2014 06:38 AM
Gangsta101
Feb 10, 2013 01:50 AM
Tony1M
Sep 25, 2009 07:59 PM
romspacenut
Dec 17, 2008 10:09 PM
kennilope
Mar 1, 2007 08:15 PM
