2003 Honda accord v6 ex- battery drain
Old Apr 2, 2013 | 06:50 PM
Steffyj862's Avatar
Default 2003 Honda accord v6 ex- battery drain
I have a 2003 Honda accord v6 ex. The battery keeps dying. Jumped it off about 5 hours ago & it's dead again. When I open the door the dash lights come on & the ignition switch dings like the key is in. Please help if you can!
Old Apr 2, 2013 | 08:11 PM
Are you sure the alternator is charging it? If so, then you'll be looking for some parasitic drain. Look for the easy stuff first, like a trunk lamp the doesn't turn off. Brake lamps stuck on?
Otherwise, it could be an alternator problem.
Old Apr 3, 2013 | 07:00 PM
Did you have the battery tested? I agree with Jim the charging system and a draw are "in play" but I have to add a battery that can't hold a charge is in play as well. An '03, figure 5 years (avg life of a lead/acid battery), you are due for a third battery by the stat's.
Old Apr 3, 2013 | 09:05 PM
Yeah, a battery that can't hold a charge is certainly possible.
What if you charge the battery then disconnect both cables? If the battery STILL goes dead, then it's positively a bad battery.
donwen1331
Mar 10, 2022 11:40 PM
DemonYusuke
Sep 27, 2010 11:36 PM
nickel11
Jun 19, 2010 12:22 PM
kellysa111
Mar 26, 2009 09:52 PM
jon02accord
Mar 26, 2008 10:54 AM
