2003 V6 Air/Fuel sensor LAF fuse blowing
Old May 20, 2014 | 10:26 AM
mac5155's Avatar
Default 2003 V6 Air/Fuel sensor LAF fuse blowing
I'm about at wit's end with this one. Have replaced both sensors, checked all the wiring, but the #4 15a fuse keeps blowing. How far back from the connector should I be checking wiring? I am going back as far as I can see.
Old May 20, 2014 | 12:00 PM
1. Have you tried unplugging both front and rear air/fuel ratio sensors, and see if the fuse still blows?
2. If the fuse still blows with the two air/fuel ratio sensors unplugged, at Connector C251, test for continuity to body chassis/ground at terminal pin wires #12 (it will be Blu/Wht on the male side, and Wht/Blk on the female side). There should be no continuity.
Leave the connectors for the front and rear A/F ratio sensors unplugged when you test for continuity.
There are actually a few other connectors that I haven't mention yet.
Attached Thumbnails 2003 V6 Air/Fuel sensor LAF fuse blowing-connector-c251.jpg   2003 V6 Air/Fuel sensor LAF fuse blowing-c251-terminal-views.jpg
Old May 20, 2014 | 12:13 PM
You may already know; but, just to be clear: your V6 has:
  • front A/F ratio sensor
  • rear A/F ratio sensor
  • front secondary heated oxygen sensor
  • rear secondary heated oxygen sensor
Under-dash fuse no. 4 protects the A/F ratio relay circuit.
Old May 20, 2014 | 12:21 PM
mac5155's Avatar
Yep, was aware of that, thanks redbull.
I will check that connector this evening. Could a bad relay cause the fuse to blow?
Old May 20, 2014 | 12:24 PM
Yes, a bad relay can cause it.
Old May 20, 2014 | 12:29 PM
mac5155's Avatar
I will check it as well. It's been frustrating, because I was showing something like 4 codes. Replaced the sensors and fuse and thought I was good to go, but now I'm getting 0135 and 0155 i believe (haven't checked in a while).
mspearin
Sep 28, 2024 04:07 PM
meazz1
Dec 15, 2017 07:35 PM
Da Flash
Jun 6, 2011 10:03 PM
BHoward711
Apr 12, 2010 08:57 PM
jbraly
Sep 1, 2009 01:26 PM
