2004 Accord EX V-6 Window Stuck Down
Old Feb 24, 2011 | 04:54 PM
Dogro's Avatar
Default 2004 Accord EX V-6 Window Stuck Down
Hello all - new to the site, but have searched high and low for this before posting. I am sure it is there, but couldn't find this one.
My passenger window was all the way down and won't go up now. Before replacing the motor / window regulator I need to get the window up so the car doesn't get to wet.
I know about the two bolts and loosening them, but since the window is all the way down and won't go up more than an inch, I cannot see the bolts to loosen.
I just want it up until the parts arrive so I can replace the motor / regulator.
Any help, guidance or direction is appreciated.
Apologies if this was posted somewhere else.
Dogro
2004 Accord EX V-6 Sedan
Old Feb 24, 2011 | 05:36 PM
You will have to remove the door panel to access the connection to the window and motor.
I would use a 12V test light to see if the switch is sending power and ground to the motor.
SkyhawkCaptain
Jun 11, 2011 10:56 AM
Wicked Pete
May 15, 2010 04:36 PM
hondagirlie
Jan 22, 2010 07:01 AM
soarass
Jan 22, 2010 06:42 AM
