2004 Accord, No Crank with Video
See video of attempts to start the car
https://youtu.be/U_4LHIsB_AA
Battery seems ok (12.8 volts). Starter replaced 2 years ago.
When you turn to start, no clicking, and driver's cluster lights have Zero dimming. Only the center cluster temp and clock lights go out.
Any ideas??? I'm thinking maybe ignition switch.
Much thanks
Zig
Much thanks
Zig
I have the ignition switch out now, so will test later.
Sadly it seems I do have continuity from the ig switch power wire (white) and start lead (white/black). That should mean the switch is good.
Back to your suggestion, what does it indicate if the brake lights do not come on?
Thanks
Zig
Thanks
Zig
Final answer, it was the starter.
Pulled one out of another car at pick a part for $28 and successfully installed. It had reman date of 2017, and works better than the last one ever did!
Last one bought at one of those parts stores just 2 1/2 years ago.
Honda wanted $700-750 for the job and local shop $590.
Z
Z
When my starter was failing. I had to hit it with a hammer to start it . Replacing the starter was not a difficult job on my car (except I almost rounded off the mounting bolts -because I didn't have ratchet and extension on straight -needed wobbler). I have no idea why they want $700. Glad you found the problem. I'm shocked you got a starter for $28!
Stonent
Aug 2, 2012 07:18 PM
