2004 Accord, No Crank with Video
Old Jul 6, 2019 | 05:38 PM
zigmeisterxiv's Avatar
Default 2004 Accord, No Crank with Video
See video of attempts to start the car
https://youtu.be/U_4LHIsB_AA
Battery seems ok (12.8 volts). Starter replaced 2 years ago.
When you turn to start, no clicking, and driver's cluster lights have Zero dimming. Only the center cluster temp and clock lights go out.
Any ideas??? I'm thinking maybe ignition switch.
Much thanks
Zig
Old Jul 6, 2019 | 07:46 PM
When you press the brake pedal, do the brake lights turn on?
Old Jul 9, 2019 | 10:19 AM
I have the ignition switch out now, so will test later.
Sadly it seems I do have continuity from the ig switch power wire (white) and start lead (white/black). That should mean the switch is good.
Back to your suggestion, what does it indicate if the brake lights do not come on?
Thanks
Zig
Old Jul 9, 2019 | 07:46 PM
That your brake light switch isn't working and will not let you start the car. You could also try the shift lever release and see if the car starts from neutral.
Old Jul 9, 2019 | 10:46 PM
Yeah after thinking it over realized you were getting at the brake switch .
Brake light works, but 2 circuits in the switch so I'll give it a closer look tomorrow.
Thanks
Z
Old Jul 11, 2019 | 08:21 AM
Brake lights work and shift lever lights changes with position.
Start relay is good, looks more and more like the starter
Z
Old Jul 15, 2019 | 10:36 AM
Final answer, it was the starter.
Pulled one out of another car at pick a part for $28 and successfully installed. It had reman date of 2017, and works better than the last one ever did!
Last one bought at one of those parts stores just 2 1/2 years ago.
Honda wanted $700-750 for the job and local shop $590.
Z
Old Jul 15, 2019 | 11:33 AM
Thanks for letting us know. It's too often that we never find out the end of the story.
Old Jul 15, 2019 | 03:21 PM
plenum's Avatar
When my starter was failing. I had to hit it with a hammer to start it . Replacing the starter was not a difficult job on my car (except I almost rounded off the mounting bolts -because I didn't have ratchet and extension on straight -needed wobbler). I have no idea why they want $700. Glad you found the problem. I'm shocked you got a starter for $28!
welchineer
Nov 21, 2017 11:05 PM
Stonent
Aug 2, 2012 07:18 PM
nontimor
Dec 14, 2011 05:24 PM
geode
Aug 24, 2010 09:47 PM
maro
Apr 11, 2007 06:51 PM
