2004 Accord vibrates between 55-60mph on acceleration
Old Sep 10, 2010 | 10:06 PM
ReadyToRetire's Avatar
Default 2004 Accord vibrates between 55-60mph on acceleration
Greetings:
The vibration occurs only when the car is accelerating between 55-60mph and then it goes away. There are no issues at any other speeds. Although, the steering wheel feels fine and smooth, I feel the vibration within the rest of the car. I've also had a rotate & balance done, but it didn't help.
It's an 04 Accord 55K miles, 4cyl, auto. The tires are still new and I recently had the front rotors and rear brake drums resurfaced.
p.s. I've done searches on this site, but have not seen any definitive answers yet.
Thanks....
Old Sep 10, 2010 | 11:10 PM
Any worn suspension component could cause a problem.
I would check for loose ball joints by putting the front of the car on jack stands, turning the steering wheel until it locks. Try to push/pull the tire at 3/9 and 6/12 o'clock. There should be very little give. If there is, try to find the source of the movement.
Also inspect the boots for the CV joints for tears and grease leaking as in your links to honda-tech (which I removed).
Old Sep 10, 2010 | 11:23 PM
Talking Hello New Member
Originally Posted by ReadyToRetire
Greetings:
Thanks....
When They checked those tires and rebalanced them they should have done an alignment at the same time. Then they could have checked all your suspension parts.
Go back and have them check it if they have an alignment machine..if they don't have a machine I wouldnt use them any more...
Attached Thumbnails 2004 Accord vibrates between 55-60mph on acceleration-911wtc3_11_400.jpg
Old Sep 14, 2010 | 07:28 AM
mkraft's Avatar
did the vibration occur after the new tires were installed because even new tires can be out of round tires.
Old Sep 14, 2010 | 01:16 PM
The tires have been on for more than a year. They've already been rotated/balanced/aligned and it didn't help.
The vibration started last month right after my extended warranty expired . I don't feel it in the steering wheel. It's down near my feet especially where my knee touches the center console. If I take my foot off the gas (or shift to neutral) the vibration stops.....
Old Sep 14, 2010 | 04:13 PM
Vibration goes away when you let off the gas? That makes it sound like inboard CV joints on the axles. That joint can be loose even if the rubber boot is intact.
Old Sep 14, 2010 | 11:41 PM
deserthonda's Avatar
i would have to agree with Jim,,sounds like inner cv joint issue ( worn or lack of grease) ,,,,,,,,,,pull the inner cv boot back, ( remove the clamp of course),, stuff the inner joints with axle grease ,re-clamp the cv boots and test drive it , see if that helps ,,
Old Sep 15, 2010 | 08:54 AM
Are the cv joints replaceable? I've only seen parts for the entire cv axle shaft assembly....
DanR217
Oct 2, 2014 10:59 AM
bobbydigital
Sep 3, 2012 06:06 PM
mikepsca
Dec 16, 2009 01:06 AM
axp
Jul 20, 2009 08:40 AM
ksomesula
Apr 23, 2009 05:26 PM
