2004 Coupe lifting points
Old Feb 3, 2007 | 03:32 PM
tucsonsx
Default 2004 Coupe lifting points
While I'm waiting for my service manual to arrive, I was hoping someone could identify the lifting points for a floor jack on a 2004 Accord Coupe LX - Thanks!!!
Old Feb 4, 2007 | 04:35 PM
deserthonda's Avatar
Default RE: 2004 Coupe lifting points
welcome to HAF......
if you look under the car, behind the frt wheel and in frt of the rear wheel you will see reinforced higher spots.. that's where you jack the car up from.....
Do you live in tucson ?? or since it says Tucson X you used to live there ?
Old Feb 7, 2007 | 12:31 AM
tucsonsx
Thanks for the reply - after posting this I looked under the car and saw the large arrow molded into the plastic underpanel pointing to a reinforced area of the front crossmember, so I used that and the rear tie down ( like all the other Acuras and Hondas I have worked on) to lift the car with the floorjack and put the jackstands under the areas you mentioned. Just today my manuals arrived from Helm Inc. and confirmed the procedure - and yes I do live in Tucson. Check out the avatar - tucsonsx is tucson and nsx combined into one word.
JMH
Mar 13, 2011 07:00 PM
armado
Mar 29, 2008 02:07 PM
alkaline747trio
Feb 5, 2007 11:57 PM
LeakinLX
Jul 6, 2006 11:24 PM
drs
Dec 12, 2005 03:59 PM
