2004 honda Accord EX won't start
Old May 9, 2015 | 07:49 PM
IbcajunB's Avatar
Default 2004 honda Accord EX won't start
had a dead battery and replaced it. Then ran out of gas before geeting to station. Put about 7 gal gas in over 1/4 tank. Now it won't start. Acts like not firing, everything works normally Tried resetting the radio code and the radio works fine. Navigation system don't reset unless its running Can anyone tell me what the problem may be?
Thanks
Old May 9, 2015 | 08:33 PM
1. When you try to start the car, are there any indicator lights flashing? For example, like the Immobilizer key symbol?
2. Does the headlights work?
3. Try pressing the gas pedal down half way to start the car. Do not crank for more than 15 seconds if it doesn't start.
Old May 10, 2015 | 07:53 AM
IbcajunB's Avatar
No there are no lights blinking. I turn the key to the on position for about 3 seconds then off again repeat several times to prime the injectors can hear the fuel pump come on and shut off and I know it is getting fuel. it seems to be its not firing. Thanks for your response.
Old May 10, 2015 | 07:57 AM
When the key is turned to on, the green key light should come on for ~2 seconds....then when the key is turned off you should get 5 blinks.
Old May 10, 2015 | 08:04 AM
For giggles, check the #7 10amp fuse in the underdash fuse box.....Sorry Redbull I'm slow at where you were going
Old May 11, 2015 | 12:34 PM
IbcajunB's Avatar
Default 2004 accord ex wont' fire
What is the immobilizer and how do you fix. Anybody Know. Because my friend has a 2004 Honda ex, and I think he ran it out of gas, but before that we had to replace the battery. After doing that and putting about 10 gals. gas. it just flat out will not fire.
Old May 12, 2015 | 12:03 AM
How have you verified the immobilizer is the problem?
Old May 12, 2015 | 05:59 PM
Merged threads so the "story" flows better.
OP- Have you checked the fuses that are listed? Call the dealer and get the brake over ride code and see if that will start the car if the fuse(s) are good and you still don't get the green key light when key is on.
Also, does the CEL/MIL light come on when the ket is turned to "on"/pos II?
Tony1M
Nov 6, 2023 08:29 PM
Sheri6889
Jun 17, 2015 08:19 AM
Hondataco
Jan 31, 2014 10:14 AM
Maverick7
Aug 31, 2012 10:21 AM
