2004 Honda Accord Need Help!
Old Feb 5, 2021 | 11:42 AM
maxwell369's Avatar
Old Feb 5, 2021 | 12:23 PM
Seanjordan20's Avatar
Ignition switch. I would change the relay also.
Old Feb 5, 2021 | 01:08 PM
maxwell369's Avatar
The car cranks though, in the video the clicking is coming from the fuse box. it clicks once when i turn the key to 1 and click like crazy during crank and right after cranking.
Old Feb 5, 2021 | 01:09 PM
rockhoundrob's Avatar
Have your battery checked. That rapid clicking makes it sound like your battery is strong enough to light up your dash, but too weak to turn the starter.
Have someone lift the hood, and you try cranking. is the clicking coming from the starter? If so, then check your battery.
Old Feb 5, 2021 | 01:10 PM
maxwell369's Avatar
Old Feb 5, 2021 | 01:11 PM
maxwell369's Avatar
the battery was just charged, the clicking is coming from the fuse box
Old Feb 5, 2021 | 01:12 PM
Ok so just replace the starter relay. It's the panel just above the fuse box you were looking at. The relay you're looking for is the st relay should be the bottom right. But as I said before I would replace the relay and ignition switch
Old Feb 5, 2021 | 01:15 PM
maxwell369's Avatar
the car was running fine, then one day while it was running, all the lights on the dash went crazy, there was a whole bunch of clicking and the car shutoff, since then it wont start, and theres clicking from the fuse box. idk if the fuse box is broken or what.i checked all the fuses and the relays...
Old Feb 5, 2021 | 01:16 PM
I'm sorry thinking of wrong car. It the ignition coil relay. Top left brown relay
Old Feb 5, 2021 | 01:18 PM
maxwell369's Avatar
i just replaced both of the brown ones, the top left, and top middle one. as well as checking the rest of them for the click and resistance
