2004 Honda Accord Need Help!
Old Feb 5, 2021 | 01:35 PM
Seanjordan20's Avatar
Originally Posted by maxwell369
i just replaced both of the brown ones, the top left, and top middle one. as well as checking the rest of them for the click and resistance
Well there you go. Ignition switch is intermittent
Old Feb 5, 2021 | 01:40 PM
maxwell369's Avatar
but if the ignition switch was bad, would i be able to crank the car, and still have all the electronics like radio and ac?
Old Feb 5, 2021 | 01:54 PM
maxwell369's Avatar
ok ill order the ignition switch and replace it. thank you
Old Feb 5, 2021 | 01:57 PM
Yes if it's intermittent. I did the same as you and it worked for around 4 months then it finally went out when I was leaving the airport. Luckily I bought the part and had it in my trunk. Changed it and I was good. When I was troubleshooting I changed my starter and relay. I would say check your starter to make sure it's good but my issue was the switch.
Old Feb 5, 2021 | 02:10 PM
It is likely the ignition switch. Another moderator on this board (Texashonda) previously stated something to that effect; the rapid clicking is due to low voltage (from high resistance at the ignition switch contacts) going to the starter cut relay, which results in the rapid oscillation of the relay contacts.
Old Feb 5, 2021 | 02:37 PM
maxwell369's Avatar
ok thank you everyone, i really appreciate it. ill order it today and update this when i replace it.
l0kz
Mar 14, 2012 11:52 PM
kathy
Aug 20, 2011 09:17 PM
trmccone
Sep 4, 2009 07:11 AM
victorcay
Aug 17, 2008 09:54 AM
