2004 v6 Accord EX
Old May 12, 2010 | 04:11 PM
TerrySS's Avatar
Default 2004 v6 Accord EX
My oil has a gas smell. What could cause this? I this a common problem? What should I do?
Thanks Terry
Old May 12, 2010 | 06:16 PM
deserthonda's Avatar
first,, i would replace oil and filter..
you need to monitor it,, make sure that there is not a leaking injector,,
Old May 12, 2010 | 06:36 PM
TerrySS's Avatar
Default change oil, monitor
Do you think there would be a problem to change the oil, and, drive 200 or so miles? How can you check if it is a leaking injector? is there an inline gauge that I could put inline? How much pressure drop would be acceptable?
Old May 13, 2010 | 06:27 AM
Leaking injector isn't so much a problem while driving (especially long trips). It's when you shut off the engine it leaks, and if you only drive short trips the gas never gets a chance to evaporate out of the oil.
Old May 13, 2010 | 08:33 AM
random888's Avatar
If you have a leaky injector, then the residual fuel pressure in the line would drain into the cylinder. You can tell by driving, letting it cool down, and pulling the plugs to check for damp plugs.
When you try to start your car after its set for a while, does it instantly fire, or do you have to crank it?
natareno92
Jan 6, 2015 01:30 PM
04accordhfp
Oct 30, 2010 08:17 PM
ranst20
Apr 6, 2006 02:17 AM
ajk8865
Apr 6, 2005 04:52 PM
sviana
Dec 7, 2004 03:09 PM
