2005 Accord EX Sedan P0420 Error Code
Check Long Term Fuel Trim (LTFT) w/ an OBD2 scanner. If it's near zero (not sure how near zero but probably < +/- 5%) and not changing, things are fine.
If LTFT is running higher than -5 to -10% or more, then excess fuel is being added and ECU is attempting to compensate.
Are you sure your scanner won't indicate LTFT? I thought I read it was able to read O2 sensor voltage signal? This level of scanner usually will scan all the key outputs.
LTFT will reset, but it doesn't take long to establish a new trend. Perhaps 10-20 mins of driving.
