2005 Accord - low speed brake noise
Old Feb 22, 2010 | 08:49 AM
skwimjim's Avatar
Default 2005 Accord - low speed brake noise
I'm having a low speed brake groan coming from both front wheels on my 2005 Accord. It all started last fall when I had the rotors turned and put on new ceramic pads. When coming to a stop, both front wheels would groan from 5-0mph at moderate brake pressure. I figured that having the rotors turned made them just the right mass to set up a harmonic vibration. So I replaced the rotors as well and it all went away. Now they're both groaning again. Anybody else experienced this? They work fine otherwise.
Old Feb 26, 2010 | 06:21 AM
skwimjim's Avatar
bump to top
Old Feb 26, 2010 | 06:49 AM
Usually brake noise is related to the pads moving within the caliper bracket.
Try taking out the brake pads, then clean up all the shims that are installed along the pad's backing plates, and the top & bottom clips in the caliper bracket (#13). Apply a bit of brake grease between each shim & pad. Also a bit of grease at the top & bottom of the pad backing plate, where it rides in the caliper bracket.
Be careful not to get any grease on the actual braking surface.
Old Mar 10, 2010 | 06:53 PM
skwimjim's Avatar
Default 2005 Accord Brake Groan - update
I greased the points where the pads contact the calipers and mount brackets over the weekend. The groan seems to have been reduced, but has not gone away completely. Hmmmm...
Old Mar 10, 2010 | 07:13 PM
Noises are tough, because I can't hear it from here.
zoid_99
Jul 21, 2011 05:14 PM
irhunter
Mar 23, 2011 04:49 PM
dwm1225
Mar 30, 2010 02:05 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
fitz
Apr 1, 2006 07:07 PM
