'92 High speed miss; low speed stall
Old Jun 2, 2010 | 10:36 AM
irhunter's Avatar
Default '92 High speed miss; low speed stall
Hi,
It's me again. I have been away from my Honda for two months. To recap the problem:
1. Drive on interstate four hours, no problem
2, Notice occasional high speed miss
3. At exit, experience low speed stall with nearly instant re-start on its own
4. Return the four hours with occasional HS miss and LS stall
Once during #4, the CEL came on and eventually went off.
Now, I short the trouble code connector and get upon moving the key to #2 position:
one short blink
one moderate-length pause
then 100 short blinks...I gave up after 100.
Suggestions? Thanks,
Roy
'92 AT 2-door LX 130k; recent timing belt change
Also note: I had a similar, but worse problem, a week before I discovered this problem. The earlier problem was "solved" with a new rotor and rotor shield (which was busted into 2 parts when I bought the car)
Old Jun 6, 2010 | 06:27 PM
irhunter's Avatar
Anyone?
Thanks,
Roy
Old Jun 6, 2010 | 06:47 PM
Does the Check engine light turn on for ~2 seconds when you turn the key to the II position (don't try to start the car)?
Old Jun 7, 2010 | 07:02 PM
irhunter's Avatar
Hi PA,
I pull out the paper clip jump wire; turn the key to "on" and all the normal dash lights come on including the CEL. The CEL stays lit for about 2 seconds and then goes out. The car starts and runs fine.
I think it will not act up until it is driven for a good while.
Thanks,
Roy
Old Mar 23, 2011 | 09:38 AM
irhunter's Avatar
OK, I am checking back in and letting everyone know how this worked out.
To recap:
1. At 40 mph, tach slammed to zero and car stalled; started right up
2. Later after 4 hours of highway driving, got a high-speed miss; then when I exited, got low-speed stall with instant re-start.
Never a CEL.
I was never able to adequately diagnose the problem; I hate throwing parts at a problem, but that is what I did and it worked.
10 months ago, I slapped in OEM: cap, rotor, rotor shield, ignitor, and coil.
The problems seems to have been solved. Thanks to all who helped with this.
Roy
Old Mar 23, 2011 | 01:37 PM
Thank you for posting a solution. Glad that you figured it out.
That flashing check engine light is strange. The way you describe the problem, I would guess that the ignitor was the culprit.
For other people with the tach dropping to zero, some O'Reilly Auto Parts stores have a machine that can test the ignitor.
Old Mar 23, 2011 | 04:49 PM
irhunter's Avatar
Hi PA,
I, too, thought it was the ignitor. But, someone wrote that a bad coil can wreck a new ignitor.
I think one of the causes of my inability to diagnose, was that the problem only showed up after the car ran at highway speed for many hours. And, immediately after a stall, it would start right back up.
Transient, intermittent, under-certain-conditions-only problems are the worst.
Roy
mechanicalsteve
Oct 19, 2014 08:23 PM
Haccex
Jul 12, 2010 04:56 PM
David W
Apr 8, 2009 09:09 AM
HondaAccordNewb
Oct 18, 2007 06:51 AM
jary
Jul 25, 2006 09:46 AM
